 at last !!!
Previous Page | Next Page
Page: of 3
Posted - 05 Dec 2011 :  12:33:37  Show Profile  Reply with Quote
Any chance there is an aluminum center console you're not using?
'68 sunbeam rapier fastback {B341006846 OD/LHO}
Autofastback
Posted - 05 Dec 2011 :  13:32:48  Show Profile  Reply with Quote
Hi in wot state is the drivers door. Are the door plate trims ok have you a price in mind thank paul
andyb
Posted - 05 Dec 2011 :  14:21:31  Show Profile  Reply with Quote
fastback thomas
its an auto so the alloy plate hs a slot rather than a square hole
autofastback
the doors are shot, it has the sill trims, the ones on mine are missing so will have to have a look in my spare trim box to see if i can match them up
i have loads of trims i didn't know where thay all went until i looked at the donor car !
sometimes nothing can be a real cool hand
Edited by - andyb on 05 Dec 2011 14:27:27
Posted - 05 Dec 2011 :  14:58:35  Show Profile  Reply with Quote
Damn, of course should 've thought about that...
Thanks anyway.
But, maybe I could make one aluminum panel, shouldn't be that hard...
any thoughts?
jabe1807
Norway
Posted - 05 Dec 2011 :  17:03:20  Show Profile  Reply with Quote
Hi
I would very much like to buy the allow sump.
I have bought a boot lid from Jon, so maybe you can talk with him about sending it to Norway. Can you send to me your pm adress? I adress is: jan.bekkelund@gmail.com.
Regards Jan
Originally posted by Jon
Originally posted by andyb
got the donor car home !
removed the dash yesterday and the trims & seals that i need all the window regulators are better than mine so they can come out, the car is in a very poor state having been stood in the grounds of a scottish castle since 1977
the front wings are poor but it does have an alloy sump (jan)
the carpet is u/s as water has got in via the aerial hole on the front scuttle
Can you put a pic up of the wings as I still might be intrested. As there more than I have at the mo!
Hillman Avenger MK1 GT,
Commer PB Pick-Up x2,
Commer PB Panel Van,
Dodge spaceavan Auto sleeper,
Triumph Stag MK1,
Chevette HS x2,
Lancia Delta Integrale,
Fiat Mk1 Uno Turbo,
Here are some of my previous restos: http://www.turbocollective.net/phpBB3/viewtopic.php?f=49&t=1643&sid=e955c8d8a55dcf5aac9b7e2509ead07c
http://66.129.69.181/forum/topic.asp?TOPIC_ID=4594
http://66.129.69.181/forum/topic.asp?TOPIC_ID=4966&whichpage=1
andyb
Posted - 06 Dec 2011 :  11:32:54  Show Profile  Reply with Quote
no probs jan, i will save the sump for you
taking the engine out will be the last job so it will be after christmas i am sure.
jabe1807
Norway
Posted - 06 Dec 2011 :  19:05:14  Show Profile  Reply with Quote
Great! It was the only missing part to my Holbay replica engine
You can give me a message on PM when it is ready (jan.bekkelund@gmail.com).
Can you send to me your PM adress?
Best regards Jan
Posted - 07 Dec 2011 :  09:58:23  Show Profile  Reply with Quote
Have been thinking about it... Could I enlarge the hole in the center console to something similar to a manual?
andyb
Posted - 07 Dec 2011 :  15:19:49  Show Profile  Reply with Quote
you could give it a try !
i might still find on in a box of unopened parts !
Posted - 07 Dec 2011 :  15:33:32  Show Profile  Reply with Quote
Let me know if you found one...
I'm going to do some "research"
I'm going to have a look at a humber sceptre auto center console... to see how big the whole is... and if i could fabricate something not to far of the original...
Thanks Andy!
Posted - 08 Dec 2011 :  00:00:43  Show Profile  Reply with Quote
Hey Andy.... what H120 parts are you looking for?
Tim.
andyb
Posted - 08 Dec 2011 :  14:54:07  Show Profile  Reply with Quote
boot lid/ engine/carbs /rocker cover / 4 branch etc
any uprated springs /dampers or info on what fits
jabe1807
Norway
Posted - 08 Dec 2011 :  15:47:24  Show Profile  Reply with Quote
Hi
I have an extra Holbay rocker cover you can get.
Regard Jan
Posted - 08 Dec 2011 :  19:51:52  Show Profile  Visit 1922's Homepage  Reply with Quote
Early model Sierra springs will fit the '73 onwards type struts - I used 40% uprated front springs on both my Rapiers.
If your car is earlier I think you will have to get springs made up, or find some '73 or later front struts.
Edited by - 1922 on 08 Dec 2011 19:52:24
Posted - 11 Dec 2011 :  15:39:18  Show Profile  Reply with Quote
I probably have everything here except the block. I have....
Holbay cylinder head c/w valves & springs
Holbay camshaft
4 x flat top pistons (standard size)
Inlet manifold (Weber type)
Exhaust manifold (4 branch)
Holbay Dizzy
Was thinking of putting it all on ebay as a complete kit for someone who has a good standard block and wants to convert it to Holbay spec.
Page: of 3 Previous Topic Topic Next Topic
