 h120 engine
retro68
Posted - 23 Jan 2016 :  18:26:16  Show Profile  Reply with Quote
Hi all,I apologise for my ignorance but can I mate an h120 engine with a standard rapier gearbox and rear axle as I know the ratio's were different, thanks in advance, Andy.
The big stylie
Posted - 26 Jan 2016 :  10:14:23  Show Profile  Reply with Quote
Hi Andy ,i,m pretty sure there is no difference in engine block on H120 and standard.The only difference that might be a problem was the bigger clutch fitted to H120 but i,d be surprised ,as there is quite a bit of room in the bellhousing , best of luck Graham
retro68
Posted - 26 Jan 2016 :  13:46:47  Show Profile  Reply with Quote
Hi Graham,thanks for the info,I had my suspicion about the clutch,im undecided about the swap at the moment as my car is pretty original,thanks again,Andy.
The big stylie
Posted - 31 Jan 2016 :  18:44:03  Show Profile  Reply with Quote
just a thought as well, don,t know if your aware axle ratio on h120 was 3.89 not 4.22 as on standard car , i,d have to try it just to see !Pretty easy swap to do if you,ve got all the parts to hand i,d have thought , if you decide to and you need a hand let us know ,i,d be more than happy to help [dependant where you are!] i,m in west norfolk
Posted - 06 Feb 2016 :  19:57:07  Show Profile  Reply with Quote
Yes, can confirm is OK, but you'd have to fit a different flywheel if using smaller clutch, but you could use the larger clutch on the standard car just need the matching bearing and cover: as Graham says plenty of room & they use same bell-housing anyway. Cheers. G.
